Register programming for PCI-6713
We are required to implement the PCI-6713 Analog output card for Solaris x86. Give that no supported driver exists, I would assume that I need specific information on register level programming for this card. This information is not in the user manual. Additional information or alternative methods to its implementation in this environment would also be greatly appreciated.
I need only implement the analog output features of this card.
Thanks for your time.
Mike
Message 1 of 14
(4,247 Views)
In article <506500000008000000FB610000-1031838699000@exchange.ni.com>,
I don't have this specific card but I"m pretty sure you can use one of
the Comedi drivers from:
http://stm.lbl.gov/comedi/
See the link to 'Supported Hardware'. The PCI-6713 is definitely in
there. It uses the ni_pcimio.o loadable module. They give you all of
the source so it should be painless to port over to your Sun station.
I've used some of these drivers in LV for Linux. They work for me.
- Kevin
Message 2 of 14
(4,247 Views)
Thank you for your response.
I have the comedi code however my problem lies in attaching a driver to an actual device. The whole Auto-configuration process is mystifying. Once I get that done in Solaris x86 (Version 8), the actual implementation is relatively trivial.
Any ideas?
Mike
Message 3 of 14
(4,247 Views)
There is only certain hardware that have register-level programming information released. You can view our RLP resources page at http://www.ni.com/support/daq/reg_prog.htm. Unfortunatly, it doesn't seem that any 671x information is publicly available. It sounds like your best bet may be with the comedi driver.
Russell
Message 4 of 14
(4,080 Views)
In article <50650000000500000033AC0000-1031838699000@exchange.ni.com>,
I'm not sure exactly what you mean. When you say 'Auto-configuration'
are you talking about the '/usr/sbin/comedi_config' application? If this
is the case, look at line #125 of the INSTALL text file in the
comedi-0.7.x directory. It talks about Module Autoloading. I modified
my modules.conf file to autoload my das08 and das800 cards. Works fine.
Tell me if this it the problem and I may be able to help.
-Kevin
Message 5 of 14
(4,247 Views)
Sorry for the ambiguity. I am working on Solaris only. In Solaris there is an Auto-configuration process where the OS attaches drivers to the appropriate devices. This process seems pretty ad-hoc to me, and still has me guessing.
Also, you can't use the auto-configuration process if the device is not "self-identifying." I dont' even know how to tell if a device is, or isn't "self-identifying." If the device is not "self-identifying" you need a .conf file which a bunch of setting I don't yet understand either. . . .*sigh*.
Are the comedi drivers supposed to work under Solaris?
Have you done this under Solaris?
Mike
Message 6 of 14
(4,247 Views)
Is the comedi driver supposed to work under Solaris x86?
Message 7 of 14
(4,080 Views)
In article <50650000000500000094AC0000-1031838699000@exchange.ni.com>,
"monarch" wrote:
> Are the comedi drivers supposed to work under Solaris? Have you done
> this under Solaris?
Are you running LabVIEW on Solaris? Your previous posts never mention LV,
just Comedi. I know very little about Solaris and Sparc work stations but
I do know there are Linux distributions for the Sparc:
http://www.ultralinux.com
http://www.slackware.com/ports/sparc/
The reason why I say to go with a distro of Linux for your Sparc is
because I have no idea if the Comedi drivers will work with Solaris. That
question should be directed to their mailing list:
http://stm.lbl.gov/comedi/mailinglist.html
Have you tried to compile the
driver source yet and was it successful?
The only problem is that you may not have LV for Linux... I'm guessing
that you just started playing around with the Comedi drivers with the
hope of using them with LV for Solaris.
Well, I hope you get this running. Sounds interesting.
- Kevin
Message 8 of 14
(4,247 Views)
Thanks for everyone's help. I was able to get the driver working. . . just a matter of having all of the right numbers in the right places. Now that the driver attaches, I need to implement the various methods. Here is where the comedi driver comes in handy. Most of the methods/registers, and I/O can be pulled out of the comedi driver, so I think I'm good to go.
Mike
Message 9 of 14
(4,247 Views)
I see comments in the comedi driver that
"streaming output is not supported." You say that the driver works for you.
1. Can you (for example) generate a sine wave on an output channel?
2. Can you use all 8 channels?
The driver code seems pretty incomplete.
Could you please be more specific what you have working with this comedi driver?
Thanks.
Mike
Message 10 of 14
(4,247 Views)
