Register Read/Write Functionality
adding in some register read/write capability into evb software. no idea to where to start fro this so,looking for some AD software that that has Register Read/Write Functionality. so as to look at the code and use this part as an example for adding in register read/wrtie capability into another part of software for a different board.
every software i request/load up from AD doesnt have the functionality
*ADC board
if any one has in idea, cheers
Message 1 of 9
(3,811 Views)
What is evb or ad software? Is this LabVIEW code of some type?
Message 2 of 9
(3,800 Views)
evb=evaluation board, AD=Analog Devices
whoops!
Message 3 of 9
(3,793 Views)
I don't see where software from Analog Devices has a relationship to LabVIEW.
Message 4 of 9
(3,787 Views)
the code/software is developed on labVIEW, i wrote to AD forum too, but just incase someone on here has done something similar
Message 5 of 9
(3,777 Views)
pjh-10
Could you provide more detail on exactly what your trying to do so we can understand the context to the question.  Reading from and writing to a device is basic functionality within LabView.  The primitive or primitives used depend on the device and / or protocol.
Message 6 of 9
(3,773 Views)
You are saying two different things when you first say the software is from AD and then saying it's developed with LabVIEW. Calling an AD dll is not the same as developing in LabVIEW, in my opinion.
Message 7 of 9
(3,766 Views)
so the AD eval software, that you can get from them, does the usual analysis (FFT,Waveform,Histogram etc).
i was asking about adding into the software, the ability to read/write the register & status bits
AD use labview to write the code used on their evaluatuion software
Message 8 of 9
(3,751 Views)
You still have not explained the low level connection and protocol for the device. The functions you mention are irrelevant for the sort of access you are talking about. The specifics would have to come from AD.
Message 9 of 9
(3,736 Views)
