Regd: Database in Labview
How do I setup database connectivity in Labview ?? Since I am new to labview please help me to find it:)
(3,313 Views)
Create a .udl file, setup your connection in that. Connect that file to Open Database connection, done. 🙂
/Y
Qestit Systems
Certified-LabVIEW-Developer
(3,302 Views)
The easiest way is to NOT use the DCT. There are many threads on that topic, this is a good one here that will also provide you with some better drivers. What DBMS will you be using?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,282 Views)
You can use the Windows ODBC connection. Its in windows control panel-> Administrative Tool-> (Data Sources) ODBC.
Before that you sholud to install Microsoft Access or SQL Server database. Then you can start configuring ODBC.
If you have any further clarification please feel free replay to post.
Dhanasekaran
Software Engineer
National Instruments.
dhanasekaran.pandi@ni.com.
(3,277 Views)
