Regarding tcp/ip server side
Hello all,
hope its not too irrelevant to the labview.Smiley Tongue
I have gone through "simple data client.vi" and "simple data server.vi" examples, want to replace simple data server.vi with a simple c program on a different computer.
Can someone please hint me how to form it?? using v8.5. The ultimate need is: c-program sends the required data to client(labview) whenever it is being requested.
The labview and c-program are on different PCs.
Not sure whether simple c-language instructions inport and outport(from dos.h) will do? or do I need to do some socket programming??Smiley Tongue
Thanking you.
Message Edited by Parny on 12-09-2007 08:10 PM
(2,769 Views)
You should be able to find a good TCP example written in C on the internet.  Searching on NI's website will most likely only yield LabVIEW examples.  Here is one link I found on the internet. I would search google for "tcp" and "C" to see what you might be able to find.
Eric A.
Distributed I/O Product Support Engineer
(2,743 Views)
Thanks for the link Eric.
(2,740 Views)
