Regarding LabVIEW Integration with Siemens Polarion ALM
I hope this message finds you well.
Actually, I want to inquiry about is it possible to integrate LabVIEW with Siemens Polarion ALM?
Do you have any Connectors/ Plugins for that or can you provide us solution for that?
Please let me know ASAP.
Thanks & Regards,
Hyder
(556 Views)
I believe you should use the APIs: Polarion REST API
You should send REST requests.
(554 Views)
I have tried with REST APIs but it is showing 404 Bad Request.
(544 Views)
Tipically, when you use Rest APIs some checks are mandatory:
  • is the webserver running?
  • Do you know what kind of authentication you should use?
  • If a user based authentication is required, is your user enabled to do this kind of requests?
I also suggest you to use a third party application, rather than directly using LabVIEW. Postman is a very nice application for this kind of operations.
(530 Views)
