Regarding LabVIEW Analytics and Machine Learning
Is it possible to make LabVIEW Analytics and Machine Learning Toolkit to make compatible with LabVIEW 2016?
(1,485 Views)
AFAIK that's kind of hard. If you have access to a newer LabVIEW version and you bought the toolkit, you could maybe save it backwards. If you don't have access to a newer LabVIEW version you could be out of luck potentially.
I don't know if there would be any issue legally or technical in using community or a newer "freely" available LabVIEW version, to revert your purchased toolkit to a previous version.
If you know other programming languages/have experience with other toolkits you could also implement your own bindings to use other toolkits from within LabVIEW. But that's probably more time consuming.
(1,452 Views)
