Reference to a Type definition
Hello together,
in my main VI i have different clusters. These clusters are defined as a tryp definition.
In my subvi I want to change the colour of an element of a cluster.
Until now i habe a Reference as an Control Element in the SubVI. The Main VI forwards the reference of the cluster to the SubVI. This works fine. But if i change the Typdefinition i get an error of the subVI because of the wrong reference. (The reference dont update automatically).
Do you have a solution to fix this? Maybee something like to tie the reference to the Type definiton?
Many thanks in advance,
Johannes
(2,565 Views)
This is the kind of question that needs some code attached so we can see what you are doing.
Are you working with a regular type definition or a strict type definition?
(2,558 Views)
I am not allowed to post the code but i created an example. If you change the TypeDefintion "MainVI-Cluster" the Code dont work anymore. (I create also a Cluster a little bit different so that you can see the problem without changing anything). I hope that you can understand my problem.
(2,546 Views)
Your sub-VI needs to be able to take two distinct types of input, "Cluster" and "Cluster-Error".  There are a number of ways to write a VI that is sufficiently "malleable" to do this -- you might look into "Malleable VIs", which have the extension ".vim".
(2,494 Views)
Accepted by topic author jojo1193
1. On your Reference Control of your SubVI, upcast it to the more generic Control class by right clicking it and "Select VI Server Class" > Generic > GObject > Control > Control.
2. Drop a "To More Specific Class" Node and wire it as shown:
Spoiler
Should be straightforward but I can give you the modified code if you need it.
Redhawk
Saying "Thanks that fixed it" or "Thanks that answers my question" and not giving a Kudo or Marked Solution, is like telling your waiter they did a great job and not leaving a tip. Please, tip your waiters.
(2,480 Views)
Dear Bob_schor,
first thanks for your answer. I tried your solution but it didnt work. After a quick research i found the information, that property nodes arent allowed in Malleable VIs (https://www.mediamongrels.com/introduction-to-malleable-vis-labview/).
But nevertheless thank you i didnt know that such VIs exist. This will help me with other projects 🙂
(2,461 Views)
Dear FireFist-Redhawk,
thank you very much your solution works very well 🙂
(2,456 Views)
