Reentrant web method VIs
I would like my web service VI to handle multiple request concurrently. I found this post https://forums.ni.com/t5/LabVIEW/Reentrant-web-method-VIs/td-p/1534796?profile.language=en. It seems the reentrant web method VI is what I am looking for. However, the reentrant property is disabled in Labview 2019. Is there another way to achieve the same thing?
I am still quite new to LabView, so if you can provide more details to the solution, it will be much appreciated.
Thanks!
(2,440 Views)
Accepted by topic author abigalexinli
What do you mean by this? I think that in the other discussion it meant that the user simply made the VI non-reentrant, not that they couldn't choose the reentrant option. In both 2015 and 2020 the reentrant options are enabled for the web service method VIs, so I expect it's the same for 2019 and a quick test shows that reentrant VIs are called in parallel when making a call to a GET method.
___________________
Try to take over the world!
(2,386 Views)
Thanks!
I don't know why the reentrant options were grayed yesterday. Today I can choose the options.
I tested with two chrome browsers in the same computer, the two calls are not in parallel. But with two IE browesers in the same computer, the two calls are parallel.
(2,357 Views)
