Reduce string size
I would like to have only the last 2 digit of my string.
Exemple : I have a result in string "28C" but I would like only take 8C (the result change every time so this is only a exemple).
Can you help me please ?
Thanks.
(5,027 Views)
Accepted by topic author Zek67
Use "String Subset" and "String Length"
(5,021 Views)
Other option:
ReverseString, take first 2 chars using StringSubset, ReverseString…
(5,013 Views)
Thank you very much.
(5,003 Views)
Just to add to the fun...
String To Byte Array, Delete From Array with the length set to 2 (do not wire up the index), and then Byte Array To String with the "Deleted Subset".
(4,960 Views)
To add more: Match Regular Expression with the following regex .{2}$
Ben64
(4,942 Views)
Ben64
I always love it when one of the Gurus of Regex posts a regex solution to a string issue because I always learn from it.  🙂
Bill
CLD
(Mid-Level minion.)
(4,915 Views)
