Rectangular Pulse Generator
Hai eveyone ..........i  need to develope Rectangular Pulse Generator(Pulse Generator) and we can vary the pulse based on pulse width(ms) controls....please help me how to design rectangular pulse generator
Message 1 of 8
(9,355 Views)
Hi guru,
you want to generate a signal with x milliseconds HIGH output and y ms LOW output? The straight forward approach is a sequence with 4 frames (output HIGH, wait x ms, output LOW, wait y ms) in a loop…
Simplest could be to use counter functionality of DAQmx devices - and the example VIs coming with LabVIEW!
Message 2 of 8
(9,338 Views)
sir i created simple pulse generator by using siumalted signal and please give me another method also
Message 3 of 8
(9,317 Views)
Hi guru,
mak49 has the very same problem of generating a PWM pulse pattern - and got the very same answer as you did in message #2!
As Dennis said: it's extremely easy to chain 2 output commands and 2 wait commands in a sequence…
Message 4 of 8
(9,303 Views)
alternative build-in vis to create rectangular pulses:
Message 5 of 8
(9,277 Views)
k sir ....now i'll explain my project task first i have to create rectangular pulse generator(pulse wave) and carrier wave and we have to combine both  waves and we get the output like
Message 6 of 8
(9,256 Views)
hello sir explain me how to design rectangular pulses in labview by using square waveform,square wave and pulse pattern?????????????
Message 7 of 8
(9,069 Views)
Hi guru,
you had more than a month to do some LabVIEW exercises. Do you still have problems to use those basic function generator VIs coming for free with your LabVIEW installation?
What have you achieve meanwhile?
Message 8 of 8
(9,061 Views)
