Recording timing waveforms of digital I/O signals in LabVIEW FPGA and RT
I am working on a new LabVIEW project and LabVIEW is a new platform for me. I have cRIO 9045, DIO card 9403, LabVIEW FPGA and RT module. Is it possible to record  timing waveforms of digital signals in my present  system or  I need to procure another software module?. Please guide.
Dev
(3,014 Views)
Hey Dev2018,
The software you will need for the cRIO 9045 can be found below.
  1. LabVIEW - 2017 to current
  2. LabVIEW FPGA Module - 2017 to current
  3. LabVIEW Real-Time Module -  2017 to current
The software you will need for the NI 9403 depends on how you plan to program your data acquisition within LabVIEW:
  • NI-DAQmx - 17.6 to current - for DAQmx API
  • NI CompactRIODevice Drivers December 2017 to Current - for FPGA or Scan Interface Mode
Also, I found the following resource valuable when looking up software compatibility for different cRIO's.
Ryan B.
Technical Support Engineer
(2,980 Views)
Thanks Ryan B,
Can you please give me an example to create the digital waveforms in my case. I am trying to  plot digital signal continuously  from an NI 9403 DIO channel in cRIO 9045. I am accessing FPGA DI/O channels in LabVIEW Real time target. Which DAQmx function I can use?. I have tried the inbuilt DAQmx  example "Digital-Continuous Input.vi" but its not working, as I am not able to directly link the 9403 channels with DAQmx because they are configured in FPGA target. Please guide.
(2,954 Views)
Thanks Ryan B,
Can you please give me an example to create the digital waveforms in my case. I am trying to  plot digital signal continuously  from an NI 9403 DIO channel in cRIO 9045. I am accessing FPGA DI/O channels in LabVIEW Real time target. Which DAQmx function I can use?. I have tried the inbuilt DAQmx  example "Digital-Continuous Input.vi" but its not working, as I am not able to directly link the 9403 channels with DAQmx API's because they are configured in FPGA target. Please guide.
(2,949 Views)
Hey Dev2018,
If you follow the directions in the Using CompactRIO with the NI-DAQmx API white paper, does that help?
Also, which Programming Mode is your cRIO set in?
Ryan B.
(2,934 Views)
Hi Ryan,
I tried the directions given in  "Using CompactRIO with the NI-DAQmx API" white paper. The problem is that I can't see my channels in Physical Channels Input terminals, as my modules are configured as FPGA target with the programming mode " LabVIEW FPGA". I can see my modules If I change the programming mode to "Real Time DAQmx" (Keeping the modules in FPGA target), but during execution its returning back to LabVIEW FPGA mode. The modules 2 & 3 whose channels data I want to acquire need to configure in FPGA as per my project requirement. You can see the configuration of my modules in the attached picture.
(2,920 Views)
