Recording data to Spreadsheet
My program is meant to read incoming data, multiply it by a 6x6 matrix, and out put the data to a graph and a spreadsheet. However, while the program can read incoming data, it fails to display the data after the mathematics, and would also fail to save any data to spreadsheets. What am I doing wrong, and how can I fix it?
EDIT: Sorry about not posting the programs sooner. They are now attached.
(3,432 Views)
Gee, anything be wrong with your program.
Hard to tell at the moment given the information provided so far.
(3,429 Views)
Here are the files I'm referring to
(3,424 Views)
You can start by posting your VI.  If the VI won't post, then zip it up and post the zip file.
(3,421 Views)
Please show the code where you have the issue.
Edit: I am too late typing a reply
(3,419 Views)
Your matrix math just won't work.  If you want to use that matrix, then you have to sample 6 waveforms, each with 6 samples.  I somehow doubt this is what your really want.
(3,408 Views)
Ok. Thanks for your help.
(3,389 Views)
