Recorded voice to file
Hello, Im having trouble with this recording VI that I edited based on an example from LabVIEW. Whenever I press the "Record" button the "Stop" button becomes unresponsive and my only option is to Abort. Help pls 😐
(2,723 Views)
Mark,
You might want to uncheck the "Lock front panel until event case completes" -option on your Record-event.
Cheers,
Cerati
(2,713 Views)
Oh God thanks so much! Sorry for asking, but what does unchecking that part actually do? Im still new in LabVIEW so every detail helps me understand a bit more. Thank you again 😄
(2,711 Views)
That check mark locks the front panel so the user can't click any buttons or change any values while that event is running.
(2,705 Views)
