Record Multiple IP Camera Feeds
Right now I'm building an new video system for my laboratory and I was curious if labview could support one of the plans on the table currently. (I've googled around without finding anything verifiable).
We're thinking of using IP cameras to record video, more specifically using 2/3 of the EverFocus NevioHD 2s which give us 1080 at 30 fps with H.264 conversion.
I wanted to see if labview was capable of capturing video from these on command and recording directly to AVI files at the same resolution and frame rate (I'm pretty sure labview can handle alpha channels easily). This all to see viability before we invest more money into this path on our project.
Thank you,
Eric
(2,524 Views)
Hi Eric,
It would be best if you can contact local NI office and request a meeting with local Field Sales Engineer. They would be able to help you determine the hardware connection as well as viability of the approach. They may also suggest you different approach to solve the issue that you have.
Hope this helps.
- Meadow -
LabVIEW 7.0 - 2011, Vision, RT, FPGA
TestStand 3.0 - 4.5
(2,506 Views)
