Real-time loops
If I have a real-time loop on say a myRio and run it, I expect the code within it to execute before the duration of the cycle of the loop. If this is not the case is there any way of seeing there is a problem? For example should LabView throw an error of some sort? Or will I be unaware that this is happening.
(3,343 Views)
Real time loops have nodes on the border that let you know if a loop iteration finished late.
(3,337 Views)
Do you mean where it says error? or something else. What do you mean a node?
(3,332 Views)
Accepted by topic author tomnz
Yes.  Stretch it down.
Node is a point of connection.
(3,328 Views)
