Real time data from Labview wavelet code
In the following example I found in LabVIEW help: Can I use CWT (Continuous Wavelet Transform) to feed real time input data instead of the red-circled input? How?
Inline image 1
Please help
(3,552 Views)
I don't see an image.
What is your definition of "real time"?
(3,551 Views)
By real time, I mean actual data obtained from NI USB device through a transducer such as an accelerometer.
I'm attaching the image.
(3,549 Views)
The word "real time" only has meaning if you specify speed and jitter requirements.
Your look only spins once per second, so you should be able to do it right there after replacing the simulation with real DAQ. How many points? What have you tried?
(3,507 Views)
How to replace "simulation with real DAQ"? Can you direct to any tutorial?
(3,438 Views)
