Real time communication between Labview and other devices with both CANBus and DNP3 together
We have already used Labview running on computer  for the real time communication based on Compact rio which connects with other devices through CANBus. Now we need to add another device into our system, this device can communicate with the remote device through DNP3 (Ethernet). And there is one computer need to communicate with both the device of CANBus and the device of DNP3. I am not sure if it is possible for us to realize it.
The attachment is some description and diagram of my system.
Thanks a lot,
(2,743 Views)
Hi Zsting,
I have been looking around your issue and find out that it is supported by our PSEs so in order to give you a better answer to your questions if you have access to the NI support  I recomend you to create a Service Request and then the assigned engineer will be able to get in contact with the PSEs and that way try to get to the solution of your issue.
Sil.VI
(2,691 Views)
