Real-Time set scan mode programmatically
Hi
Is there a way to set cRIO in scan-mode programmatically? Also older cRIO devices like cRIO-9066?
I have a cRIO in a system running a FPGA application, but for automatic system IO test, I want to programmatically change it to scan-mode, do the test with IO variables and return to FPGA mode.
For newer chassis, like cRIO-9057 I use "ModuleProgMode" in the hardware property node.
But for cRIO-9066, that doesn't work.
Do anybody has an idea how to do that?
Regards Anders
Anders Pedersen Sekanina
sekanina.dk
(3,191 Views)
Hi Anders.
Unfortunately these properties are only available on 904x and 905x cRIOs.
As mentioned here.
 https://forums.ni.com/t5/Real-Time-Measurement-and/Chassis-Programming-Mode-Where-is-setting-stored/...
So unfortunately this has to be done manually on the 9066.
Best regards
Andreas
(3,113 Views)
