Real-Time Waveform Acquisition and Logging (NI-DAQmx) sample project can be used on crio 9056?
Hello
A very short question, the Real-Time Waveform Acquisition and Logging (NI-DAQmx) sample project can be used on crio 9056 under DAQmx development mode?
Thanks in advance.
(1,319 Views)
I found myself the answer: YES!
But need to change system monitoring RT loop the property that CRIO does not have...
Then you are good to go.
(1,281 Views)
