Real-Time Temperature Multi-Plotting (DAQ-Read into chart)
Greetings,
I've been trying to setup a program (Temp-Diagramm) that displays the temperature of 4 sensors in a single chart. It is supposed to grow, to longer you let it run, but not only does it display the 2D as one plot, it also just displays the last 4 seconds, instead of the whole thing. I have a single-plot version that did display continuously using waveforms(---vor 4er-plot) .
Quick Explanation of the VI:
4 Channels get read(the sensor outputs a Voltage)
I put the 20 samples into mean for a clean graph and then multiply my data to a °C value
I build a 2D-array and output it using the graph
Thank you in advance, for both soloution and feedback.
Message 1 of 8
(1,396 Views)
Can you repost your code with a lower version of LabVIEW say 2020? Most people on the forum are not on LabVIEW 2025.
Tim
GHSP
Message 2 of 8
(1,356 Views)
Sure thing, these are for ver 18.
Message 3 of 8
(1,330 Views)
Hi schmidt,
You forgot to build an ever-growing array and you forgot to present the data in the correct order (rows vs. columns) for the graph!
Suggestion:
Message 4 of 8
(1,321 Views)
Thank you very much, your variant fixes many problems, concerning the evergrowing and having more than one plot, but now a strange phenomena apears ... I have too many:
-it starts adding more and more plots, (in the top left corner you can see new lines appearing in the base configuration: new colour, thin line )
-the plots move up and down (the first/white one differently for some reason)
not really an array guy, so wrapping my head around all of this is hard.
Message 5 of 8
(1,310 Views)
Accepted by topic author Vonderschmidt
Hi schmidt,
Because you didn't copy my suggestion.
There still is a difference on how you build the array data in the shift register when compared with my image…
Once you follow my suggestion the graph will look as expected!
My suggestion - once again:
Message 6 of 8
(1,293 Views)
Thank you again, an error on my part, but what does this do, is it an output of some sort?
I was under the impression that you only need the left side of the shift registry to create the addup and have to connect the right side to somewhere, so that LabView lets me run it. I thought it works like the tunnels, a data I/O of a loop. I never saw a connection or a need for it, because my percived output/endpoint was the graph.
Message 7 of 8
(1,280 Views)
Hi schmidt,
Your impression was wrong!
All you need to know is "Think Dataflow!"...
A shift register just stores data, it doesn't "add up" anything. You define the data, you define how to append data to an array!
Message 8 of 8
(1,265 Views)
