Real Time: Dynamic Event Terminals
All,
    I'm attempting to use dynamic event registration in my real-time vi per the help on the event structure which leads me to believe it should work. However the register for events node seems to be erroring out. Any ideas? I'd like to be able to use events with a remote front panel. Is this possible?
Snippet Attached
Ken
(3,419 Views)
What does the error say?
(3,411 Views)
Hi xkenneth,
  The attached code wont work,because the registered reference (boolean 2) is not a real reference as there is no control for it on the front panel.Regarding controlling remote panels, i am not sure whether the events work or it,but i think that they should work.
Thanks and regards,
srikrishnaNF
Srikrishna
(3,409 Views)
Error code 1043.
I don't know what boolean 2 is, I have no control named that.
(3,364 Views)
Boolean 2 is the control reference control on the very left edge of your snippet.  Is this being used as a subVI and are you passing control reference into that?  Can you post your upper level VI?
(3,357 Views)
