Reading xml file
I am trying to read an xml file but it does not parse it and give me elements. The zip file is compressed .xml file.
Thank you.
Girish
(1,438 Views)
If you use Write XML data with that cluster you'll see what it should look like. It's not quite the same.
Basically you're missing:
"<LVData xmlns="http://www.ni.com/LVData">
<Version>20.0.1</Version>"
in the beginning
Qestit Systems
Certified-LabVIEW-Developer
(1,412 Views)
