Reading unicode text file
Thanks Paul! Got the file openned perfectly.
Matthew: can't seem to get your suggested setup to work. I'm using "Read Binary File.vi" with a 1D array of U16 as data type, but keep getting error 116 (Unflatten or byte stream read operation failed due to corrupt, unexpected, or truncated data). Then, "Convert UTF16 String to ASCII.vi" throws error 12 (Some system capacity necessary for operation is not enabled).
Message 11 of 17
(3,690 Views)
Sorry Matthew, I was using the wrong inputs for Read Binary File -- got your suggested method to work as well.
Thanks again!
-Bayen
Message 12 of 17
(3,687 Views)
@Matthew Kelton wrote:
I don't know where I got this, but found it when I needed to do some Unicode conversion from the registry.
It's from a post here on this forum from me where I posted that library.
Rolf Kalbermatter
Rolf Kalbermatter  My Blog
Message 13 of 17
(3,508 Views)
Thanks PJS, This helps me a lot!!!
Message 14 of 17
(3,237 Views)
Hi Bayen,
Could you please share me the same snip or the VI which you said it got working.
I tried but ended up in empty results..
Thanks in Advance.
Message 15 of 17
(1,676 Views)
I did a thing.
Does not support complex Emoji or other 4 byte characters.
Requires the Unicode toolkit from VIPM (get here).
________________________________________________________________________
"When I need the side of a building to view all the code..." -Mark Yedinak
"...when you need a navigation window to view the navigation window..." -Jeff Bohrer
Message 16 of 17
(1,559 Views)
Inside my (still incomplete) Unicode project (attached), there are the functions:
  • Read From ASCII or UTF Text File - Output Code Points.vi
  • Read From ASCII or UTF Text File - Output UTF-16 LE.vi
  • Read From ASCII or UTF Text File - Output Unicode.vi
They will read:
  • ASCII
  • UTF-8
  • UTF-16 BE
  • UTF-16 LE
  • UTF-32 BE
  • UTF-32 LE
Message 17 of 17
(1,546 Views)
