Reading one column of data from excel to an array in labview
What I am trying to do is read one column of data from excel into labview and then implement into a chart. Any help is appreciated
attached is the excel file and the labview program that has been created so far. Not sure if this program is correct or what.
(4,184 Views)
the excel file of one column i am trying to reading in is now attached
(4,184 Views)
You are in trouble just because you tried to read an Excel worksheet with a textfile tool.
Two solutions :
1/ Save your data file as a txt file (you can keep the .xls extension)
2/ use a more appropriate tool for reading. See here
CC
Chilly Charly    (aka CC)
(4,173 Views)
