Reading of a password protected excel file
Hello...
I want to export data from a password protected excel file...how it's possible?..need to use ActiveX functions? please help me
(5,382 Views)
Accepted by topic author valiyattil.26
I'm afraid that Report Generation Toolkit does not support password protected Excel files.
But you can easily use ActiveX.
Attached you will find an example of such code.
(5,310 Views)
Thank you sir......thank you very much....it's working....thanks alot...
(5,304 Views)
Sir,
Once again thank you for your code...I also want to know the same using rgt.. with rgt it's possible to write to a password protected excel file...but reading not working...sir,  I think with rgt coding will be easy.. please help me in this regard
(5,209 Views)
I was wrong in my previous statement.
RGT can open password protected Excel file but only after small modifications.
Please check solution under:
https://forums.ni.com/t5/Example-Program-Drafts/Using-password-protected-Excel-templates-for-Report-...
(5,197 Views)
Thank you sir...
(5,193 Views)
