Reading in HZ
I have a project where we want to read the frequency of a golf club head upon impact with a ball using LabVIEW. We are using an Electret Microphone to obtain this data but LabVIEW spits back voltage for readings. How do I convert these voltage readings to Hertz? Attached is what I have so far for a vi.
Your help is much appreciated!
(3,275 Views)
Since this seems like homework, I will give you a hint.
You are measuring a signal in the time domain with units of seconds, but you want to know how it looks in the frequency domain, units of Hz or 1/s.
There is something that can transform, hint, hint, the signal from the time domain to the frequency domain.
cheers,
mcduff
(3,255 Views)
Fourier Transform
In your case, there is a simple FFT VI that you can use.
(3,241 Views)
