Reading from a binary file
I'm using the "Read Binary File" example that comes with LabVIEW, only problem is, every time I try to use it, the output array has three or four zero value data points for every valid data point. I have checked with a graphical display that these are not present in the input to the binary file.
Any suggestions?
Emmanuel
(2,836 Views)
The example uses DBL as the datatype. Do you do that as well?
Look at Write Binary File to look at the proper way to write a binary file which can be read by this example.
If this didn't help you, I suggest you post the relevant piece of code, or at least an image of it (no BMPs, please).
___________________
Try to take over the world!
(2,831 Views)
Hello again,
Yep, managed to fix it with those tips, cheers!!
Emmanuel
(2,821 Views)
