Reading excel file, saving the 3x5 array data to temporary variable and changing the array elements if needed.
I made a tiny change as my final goal was to be able to edit the main data stream which is called "Final Array". I am attaching the excel file also.
Highly appreciated.
Message 11 of 12
(379 Views)
Your Vi is insufficient to troubleshoot.
We don't have your subVIs and cannot read the file. Please replace the output from the FOR loop stack with a diagram constant (Run the VI with typical settings so the indicator named "Array" contains data.  Right-click the "Array" terminal... create constant. Now enter typical data into the "Manipulated paramters in" control and do a "menu..edit...make current values default".
Save the VI under a new name and attach it here)
What are the values for the other controls,  Sheet Num, start, end, etc.)
Message 12 of 12
(365 Views)
