Reading data from spreadsheet
Hey!
I’m a mech. Engg student doing my project on remote monitoring of vibration.
The hardware I’m using is compatible with software called RT Pro.
Using RT Pro I’m able to export a Acceleration VS Time graph values into excel.
I’d like to use this excel sprdsheet to generate a signal in LV.
However the RT Pro s/f plots only 1024 points at a time, which means that there will be 1024 time data and corresponding Accl data (y values) in  excel at a time(sample sprdsheet attached  http://forums.ni.com/attachments/ni/170/241423/1/Spreadsheet.txt) The s/f continuously changes these values(y values) in excel as new values are plotted in the graph. I have attached screenshots below of the excel sprdsheet  before and after a small interval.
BEFORE:
http://imgfreehost.com/out.php?i7550_2.JPG
AFTER:
http://imgfreehost.com/out.php?i7547_3.JPG
I’m able to access the excel file in LV, but only the values in the excel file at the time of saving it are available in LV (attached the VI below   http://forums.ni.com/attachments/ni/170/241423/2/sprdshttest1.vi). Is there anyway I’ll be able to get the data in LV as and when new Y-axis values are changed in excel.
To make it more clear, I want to get these continuously changing excel data in LV and generate a signal.
I hope the question doesn’t sound very vague. I believe it might be possible to do this with ActiveX, but I’m a novice to LV and no nothing about ActiveX. Any help in this regard will be very helpful as I’m approaching my deadline.
ThanX,
DiPS
Message Edited by DiPS on 04-12-2007 11:37 PM
Message Edited by DiPS on 04-12-2007 11:39 PM
Message Edited by DiPS on 04-12-2007 11:42 PM
(3,618 Views)
A couple of thoughts:
- is the data continuous?  That is, does each new record follow the preceding one with no gap in data? If not there is no point in trying to append the data sets.
- is that really a 0.05 sec record? Getting Labview to read a new set of data from disk without gaps every 50 msec is probably not realistic.
Now if you just want to replace and update the data in Labview, and you don't care about missing data sets, it should be no problem.
(3,587 Views)
hey thanx for the reply...
ya, i know getting new data every 50usec from the HD can't probably work......
i'm indeed more concerned about changing and updating the data available to labview... basically i want a dynamic XY-chart as opposed to the static one i have now... that's the problem i'm having as LV shows only the values at the time of saving the spreadsheet in excel
(3,564 Views)
