Reading data from PLin using KDI drivers
Hi everyone,
I have a motor with ECU in which data like PCB serial number and Fazit number have been over written using Plin View Pro software. I need to read/write that existing data using labview.
So, I have created a VI to communicate Plin using KDI labview drivers to read/write data from ECU of the motors. The VI is working fine for writing the data, but sometimes while reading the data, the motor's data is being resetted to factory default values.
If I test the VI with 100 motors, 5-6 motors are being gone into default while reading. Can anyone explain the problem behind this?
I am attaching my VI here, any type of suggestions are really appreciated.
(2,021 Views)
I think most of the LabVIEW users are using the NI-XNET driver to do LIN communication. I am afraid that you might not be able to get much help from this forum on Peak-System.
I would recommend you post to PEAK-System Forum instead.
https://tmesystems.net/
(1,976 Views)
