Reading as binary file from Cloud downloaded error
Accepted by topic author alii001
Hi ali,
for me it is ALWAYS the exactly same:
1. Now you can implement the file saving/loading between pack&unpack.
2. Test for "same?" with saving files locally on your computer.
3. If item 2 is successful: test it with saving the files on your server using that obscure C# library. Is the result still the "same?"
Message 11 of 12
(531 Views)
Thank you ,handsome man ,thank you , it seems everything turns ok . you are really kindhearted\smart\strong\regulatory\wealthy in knowledge,……now I realise my English praise sentences are so poor . thank you.
it may be my poor pack\unpack algorithm that tired LV about its basic software, and then the READ block seemed struck.
I am quite lucky about that there is no much problem ,just the code efficiency and speed.
Message 12 of 12
(529 Views)
