Reading a text file with Time V Voltage info
Hi, I have text files with Time and voltage info in a separate column in each which i want to plot. The problem is that the time values are not read in correctly so I must read in the data as strings, line by line.
The data looks somthing like this
10:43:04 0.032
10:43:05 0.225
10:43:06 0.52
10:43:07 -0.563
The´colons in the time mean that if i simply read in the file directly that the time gets messed up, so i am trying to read it line by line, without success. I have tried using shift registers and while loops without success. I have tried the ´match pattern´ idea, but have been unable to generate the two columns that I want. Is there an easier solution (e.g. being able to read in the time in a way that doesn´t
get messed up?)
thanks!
John M
(2,606 Views)
Here's the parsing part. Putting it in a graph/chart should be easy, but
depends on the type of chart.
Wiebe.
"Floss" wrote in message
news:50650000000800000070D80000-1079395200000@exchange.ni.com...
line.
10:43:04 0.032
10:43:05 0.225
10:43:06 0.52
10:43:07 -0.563
The?colons in the time mean that if i simply read in the file directly
without success
. I have tried the ?match pattern? idea, but have been
solution (e.g. being able to read in the time in a way that doesn?t
get messed up?)
thanks!
John M
[Attachment parse string.vi, see below]
(2,606 Views)
Can you save that and attach it in an older version format - version 6.1 is what I have... thanks!
John
(2,606 Views)
ok.
>John
>>Hi,
>>Regards,
>>Wiebe.
news:506500000005000000C48E0100-1079395200000@exchange.ni.com...
>>> John
[Attachment parse string 61.vi, see below]
(2,606 Views)
