Reading a html file at a specified url
I have a html file at a given URL ( for example: http://etp.free.fr/1.htm)
This file contain only a numeric value
I want to read this value in order to use it in my VI
How could I do ?
Thank you for your help!
Pascal
(3,381 Views)
The LabVIEW Internet toolkit has a VI called "Get URL" or "Read URL" that
will return the document in string format.
-Jim
"Pascal Dequick" wrote:
>I have a html file at a given URL ( for example: http://etp.free.fr/1.htm)>This
file contain only a numeric value>I want to read this value in order to use
it in my VI>>How could I do ?>>Thank you for your help!>>Pascal>>
(3,381 Views)
If you don't have internet toolkit, you can do something
like the attached vi. after you get the data, you have to parse it
to extract your values.
ozan...
"Pascal Dequick" wrote in message
news:XnAP5.293$rx.9432@tengri.easynet.fr...
> How could I do ?
> Pascal
[Attachment tcp_example.vi, see below]
(3,381 Views)
> How could I do ?
> Pascal
Open a TCP Connection to host etp.free.fr on Port 80. Take a format into
string, wire a string constant to Format string and write "GET %s
HTTP/1.0\r\n\r\n" to it. Connect input one with the URL and write this
to the TCP Connection using TCP Write. Now read TCP answer and close TCP
connection.
thats it!!
chris
( o o )
( O )
# mailto: harboeck@in.tum.de
# www: www.in.tum.de/~harboeck
# phone: (089) 323 21 21
(3,381 Views)
