Reading a DLL from two VIs
Hello everyone,
I  have a problem with tthe follwing task:
I need to create an application where two different VIs exchange data through a base VI that is saved as a DLL.
The data I want to exchange is a simple string. VI 1 should write the data into the DLL and VI 2 should read it.
I can create a DLL from the base VI, but when trying to send data through, nothing happens.
Can somebody help me with this?
I simply don't understand the explanations in the LabView help, as for example the button to select a method (c-String handle, Pointer to String) is explained, but not the methods.
(3,413 Views)
Hey,
Why don't you use a functional global variable instead of dll?
Christian
(3,410 Views)
Hi Christian,
the problem is that the DLL will be in the future also be accessed from other platforms than Labview. So I need to work with a DLL. Using a global would help me for now, but unfortunately not for the future task.
(3,408 Views)
Using a DLL for data exchange doesn't sound like a reasonable approach. Depending on what your setup, mutliple things could happen, e. g. the applications call their own instances of the DLL which don't share the same memory space or the DLL doesn't stay in memory all the time... If you don't know exactly which threads are used and how the memory allocation is done I wouldn't count on that as a reliable communication channel. What about using standard communication channels like TCP/IP or OPC?
Jochen
(3,380 Views)
rpweber wrote:
Hi Christian,
This will not work. A DLL instantiated by application X can not look into the data of the same DLL instantiated by application Y. Each application has its own private heap and the DLL will use this application private heap to store its information. So data sharing between applications through DLLs is doomed.
Use shared variables, shared memory, or inter application communication through TCP/IP for that.
Message Edited by rolfk on 10-30-2009 03:53 PM
Rolf Kalbermatter  My Blog
(3,362 Views)
