Reading Postproccessing from TXT file
Good afternoon,
I'm having problems in loading data from a .txt file and postprocess them ( those data are acquired with a DAQ).
Basically in my Labview routine I acquire data and save them in a file with the function "write to delimited spreadsheet" (in column).
I'd like to load the data back on a new VI and do some post processing analysis with that.
Is there an easy way to do it? Thanks.
Marco
Message 1 of 12
(3,260 Views)
Message 2 of 12
(3,252 Views)
I already tried that, but it does not work.
Message 3 of 12
(3,232 Views)
Could you be a bit more specific?
Message 4 of 12
(3,223 Views)
When I use the function 'read from delimited spreadsheet' and run it to plot the waveform I previously acquired, Labview crashes.
The .txt file I'm trying to upload is about 6 MB, maybe is that.
Hope I was more specific.
Marco
Message 5 of 12
(3,211 Views)
What are the dimensions of your spreadsheet? Can you attach it here?
Message 6 of 12
(3,209 Views)
yes, attached a screenshot of the file.
I tried to upload both a file with 3 column and with 1, but it did not work anyway.
Can't upload the whole file because it is more than 5 MB.
Message 7 of 12
(3,206 Views)
So, the file has 3 columns, but how many rows?
Message 8 of 12
(3,203 Views)
Hi Marco,
Ever heard of ZIP?
Also place your VI you are using to read that CSV file into the same ZIP file…
(What's the sample rate used for DAQ?)
Is there an error message? Or does LabVIEW just vanish from desktop?
Message 9 of 12
(3,171 Views)
Hello Marco
so use this attached VI and try to read the created delimited string with your solution. What happens?
Greets, Dave
Message 10 of 12
(3,156 Views)
