Reading Data from oszilloscope TDS 784
Hello everybody,
my problem is the reading of data from the oszilloscopeTDS 784D from Tektronix. I have installed the right driver and used the right vi's. Firstly it works right but after I turned the waveform size higher than 2M-Samples I've got the failure ' Timeout expired before operation completed.'. It also didn't work after turn the timeout higher.
I'll be glad if someone coud help me soon.
Thanks very much
(2,771 Views)
Hello Olk,
I would like to help you but I need more information.
What do you mean with right driver and right VI’s? Which software version are you using?
Could you please answer this question? Thanks.
Best regards
AmirG
(2,754 Views)
Hi AmirG,
thanks for your help. I continued to make the connection and so I found the failure for myself. I didn't unlocked the connection between the oscilliscope and the GPIB-device.
But now it works.
(2,747 Views)
