Reading DLL function and parameters from a header file
Hallo to everyone,
I am trying to find a cute way to import the dll header file parameters to Labview Call Library Function.
Can anyone suggest a better method that typing every parameter with it's declarations?
Message Edited by jbab on 03-16-2006 03:09 PM
(2,520 Views)
I think this is what you were asking in another stream.  I don't think there is a way to do that.  For examples of passing data to dlls given the naming convention variation across environments, check out the shipping example named Call DLL.vi, which will open other examples of using call library function nodes with a datatype you specify.
I hope this helps, and these suggestions are very welcome at our feedback site - click Contact NI at ni.com, and then the word "feedback" in the lower left corner to submit a product suggestion.
Best Regards,
JLS
Best,
JLS
Sixclear
(2,493 Views)
