Reading CJC Voltage directly PXIe TB-4353
I am using PXIe 1071 with TB-4353 card for thermocouples' reads. Currently I need to read CJC voltage. The voltage is required by the 'Convert Thermocouple Reading' VI which I am going to use next.
I am able to read CJC temperature without any problems based on the approach posted here:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019N2WSAU&l=pl-PL
I thought that I need only to switch the 'Create Virtual Channel.vi' to AI Voltage, but unfortunatelly the captured value is 0 in this case.
What am I doing wrong? Maybe there is other way to compute voltage based on CJC temp.?
Thanks, Paweł
(1,495 Views)
You already get it as temperature, any reason you need it as voltage?
Santhosh
Soliton Technologies
(1,491 Views)
The  'Convert Thermocouple Reading.vi' that I am using in my LabView project requires CJC voltage insted of temp.:
https://www.ni.com/docs/en-US/bundle/labview/page/lvinstio/conv_thermcoup_read.html
Paweł
(1,468 Views)
Paweł
It's already converted, so you shouldn't need that VI.  All you would be doing is converting a temperature that was converted from a voltage back into a voltage so you could convert it back into a temperature!
Bill
CLD
(Mid-Level minion.)
(1,435 Views)
