Reading ActiveX Control Enumerations
I am using an ActiveX control that defines enumerations in an .odl file "typedef enum {RED, GREEN} COLOR;". Visual Basic can extract information about the enumeration (I can type "Dim c As MyControlLib.COLOR" and then type "c = " and VB will provide "RED" and "GREEN" in its auto-completion feature.)
QUESTION: In LabView, is there any way I can use/access these enumerations? In other words, is there a way to specify "RED" instead of zero without defining my own "patch" ring or enumeration control?
(2,769 Views)
When you drop an ActiveX property or invoke node, select an input or output and select Create.... LabVIEW will create a constant, control or indicator ring with the control names list.
Jean-Pierre
LabVIEW, C'est LabVIEW
(2,769 Views)
Thank you very much!
(2,769 Views)
