Read / write to HP 8562A spectrum analyser from Labview over GPIB.
My requirement is to send commands from Labview (in string format) to HP 8562A spectrum analyzer (SA) and read the output from the SA and write it into a text file. The interface to be used is GPIB. I have no prior experience in Labview and I am pressed for time by a close deadline. The HP 8562A spectrum analyzer is an obsolete model.
Any help will be most appreciated.
Mohan
(3,748 Views)
You can see what I had to say several years ago but this might work too well for a beginner.
If no one posts any code for the instrument. You may have to use the Instrument I/O Assistant. This is a wizard where you provide the commands from the manual and how to parse the results.
(3,742 Views)
Thanks Dennis,
I am in the process of having the IT support install the Instrument I/O assistant. Will update the discussion.
Mohan
(3,713 Views)
Accepted by topic author Mohan.R
Hi Dennis,
I got the Instrument I/O assistant to talk to HP 8562A. But I was able to write a simple program with VISA Open, Read, Write and Close VIs to read instructions and write to a file.
Thanks for the help.
Regards
M.R.
(3,679 Views)
