Read txt file several times to build a new waveform
Hello all,
I built an arbitray signal by reading the data from a txt file. Both the txt file and VI are included in the attachment.
What I am planning to do next is using this signal as the basis to built a periodical signal. In other words, the signal I have right now could be considered as a full period.
However, surely I can't generate this periodical signal by just reading the txt file several times. I think I might need to use a storage function to save the data after my reading and append them together (so the following signal won't start at time 0 again) before the signal is written to the DAQmx write block.
Anyone has a idea about how to achieve that?
Thank you very much
(3,444 Views)
a small modification of a 2011 shipping example might help
"Should be" isn't "Is" -Jay
(3,437 Views)
Hi Jeff,
Thank you very much.
Would you please tell me the name of this example file?
All the best,
Kevin
(3,435 Views)
in the 2011 examples this was sourced from "Gen Mult Volt Updates-Text File Source.vi" with some input from "Cont Gen Voltage Wfm-Int Clk-On-Board Regeneration.vi" Which is identical to "Cont Gen Voltage Wfm-Int Clk.vi"
in 2013 I strongly suspect the examples were renamed and done slightly different but, I can't check today.
(3,428 Views)
Hi Jeff,
Thank you for your information. Actually I have achieved to read the txt file to form the waveform by building my own VI. The waveform is listed as in Figure 1.
Figure 1
Now I have difficulty to output a periodical signal based on the signal I have right now. The ideal signal should be something like in Figure 2 (image achieved in Paint (windows7) )
The example VI you provided actually can only produce 1 signal, similar to figure 1. Not the continuous waveform as I desired....   😞
(3,423 Views)
Anyone can help me resolve this question?
Thank you very much
(3,392 Views)
