Read second table from HTML File
In the attached llb file, that contains a Top Level VI, I am trying to extract the second table from the HTML file with the label "Run Info".  I tried doing a search for "Run Info", but I end up with the first table.  Please note that the attached HTML file is part of a larger file.  There are other tables in the actual file.  How can I go about extracting the second Table with the "Run Info" heading.
Also, if there is another table with "Run Info" header, how do I extract that table also and create a 3D array?
hiNi
(3,181 Views)
Hi hiNI,
1. Load the HTML file as plain text string.
2. Search the string for ">Run Info<".
3.When found: Search for "<table", then for next "</table>. Keep the substring in between: you got your table data.
4. Repeat with step 2 until there is no other ">Run Info<".
(That's the brute-force way…)
(3,136 Views)
