Read repetition rate from dbc file
Hi all,
I can read dbc file in LabVIEW but, I am not able to read repetition rate. There is property "Task Sample rate" but it gives "0" for each messages.
I found few posts which tells that is is not possible, but they were old, so just wanted to check if someone has any solution over it.
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
Message 1 of 1
(2,319 Views)
