Read recordset in ADODB
I am wondering if this question is right for this forum.
I am not experienced with ADODB or Access.
The attachment is a part of tutorial of a LabVIEW project written by other.
I took much time to check if the ADODB was set properly in my computer.
and it seems to be okay.
The main program is "Get Processes to Launch.vi".
When I execute the program, an empty array was return due to BOF/EOF was TRUE in "Read Recordset.vi".
The "LocalDB.mdb" was converted from "Local DB Build.sql".
Can you check if "LocalDB.mdb" in _repos folder contained a right information or give some suggestion in the code?
labmaster.
Message 1 of 1
(2,168 Views)
