Read properties from Object?
How do I flip to the property as input, ie, I set the visible property to True / False. And notonly read the property.
How do I write in the property "visible " to a button?
In the "Front Panel" added an "OK Button ". In the "Block Diagram", right click on thebutton and clicked "create-> Property Node-> Visible", appears on the property, but onlyI can turn on a gauge.
(2,473 Views)
Accepted by topic author rodrigoevaldo
Do another right click, this time on the property node. Select Change All to Write or Change to Write and if allowed, the node will turn to one that you can write to rather than read from.
Ian
(2,462 Views)
Thank you!
(2,451 Views)
