Read .ping
Maybe seems simple inquiry,
I have some of the snippets as .ping files. like the attached.
but I can not transfer it to its terminal's contents in the block diagram!
Do you have any advice!
(2,331 Views)
Accepted by topic author BaJa_2020
Hi BaJa,
This is a PNG image, but not a "ping" file!
As that is a simple ordinary PNG image, but no "special" snippet with LabVIEW code embedded, you can only drag it as an image into the block diagram. It will (and cannot) convert to LabVIEW code magically…
(2,324 Views)
