Read lines output as string
Good morning,
I recently upgraded from 7.1 to 8.5, and found the file palette, ah, took a step to the left from what I'm used to.  Not necessarily worse, just different.
I'd like to use the Read Text from File primitive in "Read Lines" mode to read 100 lines at a time.  No problem.  However, I'd like to have it output a string, not an array of strings.
Is it possible?
(Yes, I know I can tack the array of strings together into a single string.  Why do I have to?  Or did LV always just do this under the hood?)
Joe Z.
(3,370 Views)
The Read From Text File function will output an array if you wire in a count that's greater than -1. Unfortunately, that's just the way it works in 8.x. Note that the 7.1 "version" is still available (albeit updated to use 8.2 functions). It's in vi.lib\Utility\file.llb.
(3,343 Views)
I think you can also find it if you do a search within the Function palette.
Although I can verify since there's no LV on this PC 😞
(3,334 Views)
Thanks for the replies.
Looking at the old Read Lines from File.vi... it *is* a bit of a mess, isn't it?
I'll do a bit of cleanup and comparative benchmarking to see which method works better for what I'm doing.
Joe Z.
(3,323 Views)
For the record: the two methods are almost the same as far as timing in my particular application of creating column indices.
I suspect that Read Lines from File.vi has a little more room to optimize, should it be necessary.
Thanks all,
Joe Z.
(3,279 Views)
