Read lines from text-file in specified [ITEM]
are there any functions integrated in Labview to read a text-file which looks like this:
[ITEM-NAME_01]
parameter1 = here
parameter2 = 1123
parameter3 = a453
[ITEM-NAME_02]
parameter4 = here
parameter5 = 1123
parameter6 = a453
Can this be done easy, or do i have to manually search the file for the "["-character ?
At the end i want a VI where i pass the file-name and the item-name as input, and as output i want one array with the parameter-names and the other array with the values.
How can this be done?
Thanks for your help
(2,572 Views)
Hi OnlyOne,
you are talking about Configuration files?
Look in the file palette, sub-palette "configuration files". It's all in there!
(2,570 Views)
Hi GerdW,
that  was exactly what i was looking for.
Thanks for the help.
(2,564 Views)
