Read hardware serial number
Hello there
Is there a method of reading the hardware serial number of a NI device?
Jannie
(3,062 Views)
For a DAQmx device, you can use a property node. See attached example.
  1. Functions palette >> Measurement I/O (or NI Measurements for LV7) >> DAQmx - Data Acquisition >> DAQmx Advanced >> System Setup >> DAQmx Device Property Node
  2. Put the property node on the diagram >> resize it to add a property
  3. Click on the lower property >> Identification >> Device Serial Number
  4. Wire the device to the ActiveDev property and an indicator to DevSerialNum. The serial number is a hexadecimal value and therefore you should set the string indicator to hexadecimal.
(3,044 Views)
