Showing results forĀ
Search instead forĀ
Did you mean:Ā
Read from XML performance issues
I am reading an XML file into my application the XML file can vary in size but the larger files ( say 20mb) take forever to process using the Read from XML file Vi. Any suggestions on how to improve the response time? It can take anything up to a minute if not longer
I have not lost my mind, it's backed up on a disk somewhere
Message 1 of 19
(3,861 Views)
That sounds strange, can you post vi and an example file?
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 2 of 19
(3,860 Views)
Hi
Message 3 of 19
(3,853 Views)
Can you save the code for LV2011 and post it.
I am using LV2011, I was not able to open the VI that you have sahred.
Message 4 of 19
(3,849 Views)
Here you go
Message 5 of 19
(3,841 Views)
The XML parsing taking lot of time (To be exact the "FindMatchingCloseTag.vi").Is there any specific requirement to have the file in XML format? Else you can try .bin or data log file. You can write the Cluster array and read it at a glance.
Message 6 of 19
(3,825 Views)
My file has to be in XML format the XML file is generated from another program and my application deals with that XML file
Message 7 of 19
(3,823 Views)
Holy moly! Close to 500k of lines in a single XML file! That is really HUGE.
That being said, loading this in IE9 hangs the complete IE process.
Using Notepad++, the file loads within a few seconds, but scrolling is very slow.
Using your VI, the "XML Elements" indicator fills after about 20s after start, the "value" indicator after about an additional 20s.
So LV seems to "operate" on "an average" regarding performance of reading and displaying the content of the XML file.
Are you simply looking for the content string (like Notepad++) or are you interested in "node information" directly when reading the file?
Norbert
EDIT: After writing the post (more than a minute) i've seen that the IE process settled and was responding again. So IE takes surely about or more than a minute to load and display the XML content, but does not hang competly as my post might induce.
Norbert
Expert: Geometry
Message 8 of 19
(3,814 Views)
I tried with 7 MB file and for that it took ~68 seconds to load and I can see how long it will take to load a file of around 200MB. How did you arrive at the Array of cluster? Is the other application you meant is also on LabVIEW platform?. I am not experienced with XML but trying what I can do.
Message 9 of 19
(3,809 Views)
When I read the XML file each element is displayed in a table with certain unbundled information that I want. The table is controlled by a mouse down event which clicked loads the coressponding image to the data set that has been clicked. I also use "Centre of Mass X" + "Centre of Mass Y" to draw points on an XY graph
Message 10 of 19
(3,803 Views)
